Purple Wire 4 TCC, How does the Factory Hook Up W/Cruise
Old May 6, 2008 | 09:11 AM
drb930's Avatar
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
The Purple wire to the computer from the brake light switch.
With cruise control does the factory use a special brake light switch?
Thanks,
Dave
Old May 6, 2008 | 09:20 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Purple Wire 4 TCC, How does the Factory Hook Up W/Cruise
I should double check first, however, I believe there is a separate switch for the cruise control. The the main switch handles the brake lights & TCC power feed.
The cruise switch typically has a vacuum line on it.
RBob.
Old May 6, 2008 | 11:01 PM
drb930's Avatar
The car is an 1987 El Camino.
There are 2 switches, 1 with the vacuum line to it and some small wires.
The other is the brake light switch which looks like the switch that should be used in the Painless diagram.
The problem is that the brake light switch has 3 large wires at the front part of the switch which get power from the middle terminal to the outside terminals when the brake petal is pushed.
The back part of the brake switch has 2 small grey wires that do not seem to have any power or anything.
The car is a 1987 that had a 200 tranny in to start out life with, could those grey wires be for the TCC somehow?
Thanks,
Dave
jklein337
Sep 19, 2018 06:23 PM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 17, 2015 01:29 PM
penguinpanda0
Aug 15, 2015 06:45 PM
stalkier
Aug 7, 2015 04:49 AM
