89 RS prom?
Old May 7, 2008 | 11:10 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
89 RS prom?
Buying an 89 RS, wit a 2.8 in it.
I wanna put my L98 TPI in it, should i only have to swap the engine harness and prom, and just use the same ECM.. or..??
John
Old May 8, 2008 | 01:12 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 89 RS prom?
I know the 90-92 3.1L V6's use the same 7730 ECM as the 90-92 V8 TPI's, but with a different prom. I have no idea if the '89 2.8L uses the same ECM as the 89 TPI, but I doubt it. You'll need a new ECM and PROM chip.
Old May 8, 2008 | 03:25 PM
Engine: THREEFIDDY!
Re: 89 RS prom?
Ok well how can i be sure of this.. how can i check to see if the ECM is usable?
John
Old May 9, 2008 | 02:49 AM
Kevin91Z's Avatar
Re: 89 RS prom?
Look at the TPI ECM and the V6 ECM. If they're the same part number, you're good. The '86-'89 TPI ECM has the last four digits of '7165.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
