LS1 PCM Controlled Gen 1 SBC, Coil per Cylinder, and even Electronic Throttle Control
Re: LS1 PCM Controlled Gen 1 SBC, Coil per Cylinder, and even Electronic Throttle Con
Semi interested in how you have done this, I love working with the 7730 and really doubt there is much to gain for me other than some resolution. But I am running a early SBC in 94 firebird (Just purchased some connectors off your company, t56 reverse switch and vss - thanks, very fast shipping and great communication. I had also asked about the speedo, got that working as well, between pulse devisor and using the cruise control output which is 2000 vs 4000, got 94 factory speedo pretty close. Anyway using the early SBC I have to drop K-Member to change plug wires being they are directly against bottom of cowl. I would be very interested in getting rid of the DIS..
Car: 1980 Corvette
Engine: 383 fuel injected
Axle/Gears: 3:07
Mike.....do you have any final recommendations for the knock sensors. I'm about to purchase a custom made harness from you and reluctor ring (when back in stock). The knock sensors are the last sensors I need to collect.
The first 24x LT1 conversion will be running with 96/97 LT1 knock sensors. That engine may be running in the upcoming weeks.
Fortunatley the knock sensors won't get in the way of a harness build (unless you want to try the 2 wire "flat response" type sensors...which were used with the LS2 and appear to be compatible with the LS1 PCM according to EFILive).
I was poking around AllData and found the following under DTC P0327.
The 2001 Camaro LS1 diagnostic procedure for testing the knock sensor(s) involves reading a resistance through the sensor of 93-107K ohms.
The 1996 Camaro LT1 diagnostic procedure for testing the knock sensor involves reading a resistance through the sensor of 93-107K ohms.
The 2001 Express Van 5.7L diagnostic procedure for testing the knock sensor involves reading a resistance through the sensor of near 100k ohms.
A big thanks to Mike in Wisconsin for sharing videos of his 24x LT1 installation progress. Mike sent a few videos of the engine running on the dyno. The engine may be hooked up to the water brake this week to apply load.
Keep in mind that Mike is using a calibration that we are using on our test stand. It's rough at best and needs a lot of work. However, you'd hardly know it seeing this engine run.
First QuickTime Video
Second QuickTime Video
Third QuickTime Video
Mike purchased:
- 24x LT1 crank reluctor
- he had a 24x crank sensor
- 24x LT1 conversion harness (stand alone type for his pickup truck...which works well for the dyno)
- cam sensor, housing, and target
- 96-97 LT1 crank key (GM# 12550096)
- used LS type coils (truck coils I think)
His comments have been:
- it fired up first try
- throttle response is perceived as better than with the original electronics
- a few emissions trouble codes have set (fuel level, fuel sensor, AIR pump, skip shift...all need to be disabled in the calibration)
Mike
EFI Connection
Mike purchased:
Mike
EFI Connection
Car: 1987 Z28
Engine: LG4
looks cool....what kind of price would i be looking at for doing the swap on a 91 trans am with a l98?
Beyond that, it all depends on what you are willing/able to do yourself. We're building new 24x engine harnesses starting at $650 (stand alone type), we're offering a set of new LS coils for $200, you still need tuning software, a PCM, a tuner, and other odds and ends along the way.
Mike
EFI Connection
I have just finished my main harness minus a couple of plugs that I need to order.
The LT1 crowd is beginning to make some good progress. Here are a few videos of the first 24x LT1 package installed in Wisconsin.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
what about a previous carb. sbc?
ok to use with a sbc efi vic jr, ls 90mm tb?,
car made 430rwhp n/a with vic jr, hp 750, msd ignition.
what do use to drive oil pump? lt1 dizzy?
Previous carb? You mean a pre-87 small block? A small block with a 2 piece rear seal? Everything should fit okay.
Everything should fit okay. And as long as it's a multiport V8, the intake manifold does not matter.
While I'm not claiming significant horsepower gains, let me tell you about a testing experience we had this weekend. We had an opportunity to test a distributor loaded with two optical sensors and the 24x crank / 1x cam LS1 signal. The engine started up, but by 1500 rpm the ignition broke so bad that the engine started to shake. We couldn't rev past 2000 rpm. A crank sensor DTC had set. I feel that the problems were due to the inconsistencies of the signal coming out of the distributor.
A timing chain is only tight on one side and during certain engine conditions the change in slack from one side to the other will cause the camshaft to receive the effect of the change in timing chain slack. Add to that the play in the distributor gear to the camshaft gear and the up/down movement of the distributor shaft, and now you have too much play for a consistent crank signal.
So...consider a traditional HEI distributor and the timing of the rotor to fire each spark plug. It's inconsistent and inefficient much sooner than you think.
The most consistent spark possible can only be accomplished by a crank signal from the crankshaft, 8 individual coils, and a fuel management system that can control them.
A Vortec distributor...which is required for the 1x cam signal.
Could the idea of using the vortec dizzy and the 24x ring gear be enough to plug and play the MSD LSx coil setup. You know, the MSD kit that will allow people to still use the 8 coil setup with a carb'd LSx conversion. This could be a short alternative to an ignition upgrade.
On a side note, what's with the GM cap, pt#10494292? What did GM orginally use this for anyway? Weren't all Vortec engines still cap and rotor setups?
Here's an exploded view of all the hardware involved to equip an LT1/LT4 engine with the signals required by the Gen3 LSx PCMs.
The 1x cam reluctor bolts to the cam sprocket and is located by the pin on the cam.
The cam sensor housing replaces the optispark module.
The 24x crank reluctor installs on the crankshaft and is located by the 96-97 LT1 crank key (GM# 12550096).
No adjustments. Bolt it all on and it's ready to run.
I am interested in perusing this route on my 1992 TPI 350 powered Chevy K1500.
Could anyone please explain if the 411 PCM is capable of controlling TCC lockup on a 700R4? I believe I read a post or two explaining that it was possible by simply disabling the error electronic trans bits and the PCM would continue to control the TCC lockup just as if a 4L60E were connected. Is this true?
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
One day, I noticed that he didn't have TV cable and we looked. He'd never noticed it.
If you wanted to just have the coil on plug AEM has an Engine Position Module setup http://www.aempower.com/ViewCategory...CategoryID=122, but for the PCM and crank sensors this is a nice setup he has got.
The conundrum for me is just a few years ago I invested a bit into having a 700R4 rebuilt with decent parts. I'm extremely happy with it, and I'd hate to have to swap it out for a 4L60E when it works so well.
I saw this post from Fast355 and it looks like he had it working. I guess I am hoping he or someone else may be able to elaborate a bit for me as encouragement that I will be able manage TCC lockup in my 700R4 with the 411 without messing around with vacuum switches, etc.
https://www.thirdgen.org/forums/post...38-post15.html
I'm hoping to finish assembling my 383 LO5 in the next few weeks and have been gathering the nessessary parts to run the Express Van calibration on a 411 with it when I drop it in the truck sometime this spring/summer. I just need a couple more connector pig-tails so I can rework a spare LO5 truck harness over to 411 TPI and purchase an EFI Live license.
This has all come a long way since the initial development began about this time last year.
Our achievements have been...
- 24x crank reluctor for single row timing chain
- 24x crank reluctor for double row timing chain
- Cast aluminum sealed cap for Vortec distributor
- 1x camshaft reluctor and sensor housing for LT1/LT4 engines
- Electronic throttle bodies (52mm, 58mm, mono-blade) for TPI/LT1 intake manifolds
The newest addition to the line up, electronic throttle for TPI/LT1, makes for a modern look of the TPI.
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
Been following this thread for awhile. This is a major step in the right direction for newer technology in older cars. And I love you for it
RamJet 350 manifold has been removed. TPI manifold has been installed for testing of the new throttle body. The new electronic TPI/LT1 throttle bodies work just like the electronic LS1 throttle bodies.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I am seriously considering doing this on my 91. Will most of my sensors work with the LS PCM? If not what sensors will I need to get for the LS to fit on my TPI system? Will you be offering a wiring solution for TPI?
You'll have to install the two heated O2 sensors. And if you do this conversion, the package will come with the correct crank and cam sensors.
Car: 92 Firebird
Engine: 4.8 LR4
Sending you an email soon.
Are you running knock sensors with your S10? If so are you using the LS sensor or keeping the TPI sensor?
Are the O2 sensors heating circuit controlled by the ECM or do you need to run their own heating circuit?
Does the LS also have a oil pressure switch/sender incorporated into the ECM?
Car: 92 Firebird
Engine: 4.8 LR4
Switch/Sender, no. Sensor, yes...but only if you want to use it. It's actually somewhat useless as the data stays on the Class 2 serial data line. Now if you're putting a Corvette instrument panel in your f-body, then maybe you'll want to use the sensor. Otherwise, just use the same sender that's already in your engine. As for the switch...I would forget about that functionality as GM did long ago.
This is really making me want to do this now......
The sender is used for the oil pressure gauge. The switch is a redundant power source to the pump (if the relay fails) and not a cut off safety. Have a look at the wiring diagram for your car when you have time and you'll see it has nothing to do with cut off safety. A very common (and understandable) misconception.
Car: 92 RS
Engine: 305 TBI
Axle/Gears: 4th Gen/3.23/Posi
Will there be any dyno runs to compare the different intake setups... TPI/LT/RamJet and their respective power differences?? Progress looks great... this is definitely on the to-do list down the road...
Now if we were to dyno an engine with a distributor and then with our 24x system (coil per cylinder) then that would be something significant to show.
A recent customer installed our 24x system on an LT1 engine and picked up about 25hp and 50lb/ft compared to the LT1 PCM.
In the upcoming months we should have some very useful comparisons like this in dyno chart form.
Car: 92 RS
Engine: 305 TBI
Any updates on this?? Very interested in everything as I have an LT1 swap in mind within a year or so...
Is there anything specific you would like to know more about?
Car: 92 RS
Engine: 305 TBI
Just things like any before/after dyno sheets, user feedback, etc. Has there been much user feedback posted up on any other forums that you could link us to just to see other peoples' impressions of the system?
http://www.camaroz28.com/forums/show...55#post5957755
From an email..."We ended up making 348rwhp and 355 rwtq. The best it ever did before was 32X Lowest was 29X. Now it pulls past 6k with no problems at all."
http://forum.efilive.com/showthread.php?t=11060v
Originally Posted by Brad
I recently helped install the EFI Connection's conversion kit on a '93 LT1 car to eliminate the Opti....
The car is SD with an M6. LT1 Hot Cam Kit and headers. We're currently running closed-loop until my dyno and WBO2 show up.
Excellent job with the kit Mike. It fired on the first attempt!
http://forum.efilive.com/showthread.php?t=11163
From email....
"The difference is night and day (compared to the original MEFI4 controller). The customer is very happy. As you can see from the dyno charts, its pretty dramatic. The first pull in on the RamJet the first time it came in. It had a low 10 high 9 AFR, it was 160 horsepower, and 220 torque. The second run is after the tune is competed, with a spot on AFR and 0 knock.
Thanks for all your help, and making a quality kit. ... Every RamJet should have this set up instead of the MEFI. Great work and thanks again."
Im very interested in this kit from Efi connection!! Looks top notch and will make my life alot easier when doing my LT1 swap. Just a question though?? Does anyone have any Timing and Ve tables to start with yet? A base tune for an LT1 would be great and save alot of time tuning Im sure? Cant wait to get the stoker back and put it in with that set up. Thanks for any help
Very interested in watching progress of this product. Specifically, on 93 Lt1s.
Finding someone who can tune the oddball stuff I keep installing is tough,
being able to run an LS1 computer sure would make life easier for me.
correct me if I am wrong.....you recommend getting a 2001 - 2002 fbody PCM.
but if I wanted to get the dbw TB and pedal setup upgrade , does the 01-02 LS1 PCM support it ? or do I have to get the PCM that matches the TB and pedal from the donor car? ie corvette , caddilac , GTO
I also heard that to avoid gremlins best way is to get the TB and pedal from the same exact car.
so what pedals are supplied with yopur kit and any issues with working with your custom dbw TB
First, the throttle bodies are designed to use the 99-04 Corvette Throttle Actuator Control Module (TAC).
Second, the corresponding PCM is any 98-04 Corvette PCM. This covers four different hardware numbers. Just plan on using the 2001-2002 (GM# 12200411) PCM. The Corvette used this PCM in 2003 as well. The 2004 PCMs are 1MB (not 512K). The 1MB PCMs haven't been popular, but they can be used.
Lastly, this will require the 98-04 Corvette pedal assembly. You can also use the 04-05 Cadillac CTS-V pedal assembly, as this application uses the same TAC module.
So a LS1 PCM for a 2002 TA will work. Further research on the internet go me this info that I cannot understand.
"If PCM has blue and red connectors it may not have TAC module drivers and would need to be replaced with a Blue/Green one that did "
what does this mean and what is involved. Do I have to get a os that supports dbw? or will the above pcm that I have work ?
Get a 2001-2002 PCM (GM# 12200411), do a full flash using EFILive using the operating system of your choice, and get TAC module support.
