Is this the right ECM for my car?
Old May 28, 2008 | 07:07 PM
zmasta101's Avatar
I believe I have finally found the ecm for my car under the passenger side dash. I am having issues with my car, I have to charge my battery. But, before the battery was dead the car was idling high, said it had a bad maf sensor, burnoff, and the exhaust smelled very rich. I noticed it said remanufactured on the label.
SVC# 16198259
FACTORY AUTHORIZED REMANUFACTURED MODULE FOR DELCO ELECTRONICS CORP
MADE IN: US
Can somebody PLEASE help me out here. Btw, my car is a 1988 IROC-Z TPI 350. I assumed maybe the car was running in limp mode because of the rich gas smell coming from the exhuast.
Thanks, Nick
Old May 28, 2008 | 08:33 PM
zmasta101's Avatar
Re: Is this the right ECM for my car?
I have just done some research, and it appears on these cars that a bad maf sensor will cause the car to go into limp mode. Well... a while back when I took the DTC's it only had code 34 and code 36. So I assume my car IS in limp mode. I can unplug the maf sensor with the car idling(High might I add ~ 1000 RPM) And it doesn't effect it the slighest. I read that that would point to a bad maf.
Old May 28, 2008 | 08:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 16198259 ECM is supposed to be the correct one for your vehicle.
If you unplug the MAF sensor the ECM will create an airflow value from the engine RPM and TPS%. This is not limp mode, but a default mode.
If your engine is stock and the ECM is tossing code 34 then the MAF may be bad. However,isn't code 36 a burn-off DTC? If so, then fix that first, the MAF may still be good.
Open the air ducting so the MAF wires can be seen. Start and run the engine for a minute then shut it off. At shut off the MAF wire should glow orange for a couple of seconds. That is the burn off. No glow, burn off bad. Dirt builds up on the MAF wires and DTC34 is also thrown.
Note that the MAF harness connector can also cause these same issues.
RBob.
Old May 28, 2008 | 10:21 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Also check the fuse and fusible link near the battery, that's ECM constant power. It also powers the fuel pump though, so if your fuel pump is working, that's probably not the issue. I wouldn't rule out a bad ECM though, I had 2 bad ones, one of them also had a reman sticker on it.
Old May 29, 2008 | 10:09 AM
zmasta101's Avatar
I have finally gotten my battery charged. I tried the car today and it started up after a couple tries. I still think the car is in limp mode b/c when I turned the ignition to run, the SES light just stayed solid, and when I started it the car idled at ~1200 RPMs as well as the SES light flashed continuously when the car was running. How can I tell if the memcal is right for the vehicle?
Old May 29, 2008 | 11:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With the way the SES is acting the ECM just may be bad. With the engine running rap ont eh ECM with the handle of a screwdriver (or similar). If things change (SES, the way the engine runs, etc.) then the ECM is toast.
For the MEMCAL, there is a 4 letter code on it. Most likely on a small silver label on the PROM. Post back the 4-letter code.
RBob.
Old May 29, 2008 | 12:45 PM
zmasta101's Avatar
The 4 letter code on the MEMCAL looks to be ABYA. Also, I tried letting the ecm rest outside of the dash and start the car, with it idling, I tapped on the ecm to no avail. It did not change the solid ses light or the idle of the car, they both stayed the same. Thanks man
specialized
Jun 18, 2022 09:26 AM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
djmarch
Aug 9, 2015 05:27 PM
