Will a SD ECM work in a MAF car?
Old Jun 11, 2008 | 10:23 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I got a 88 IROC with a 305 TPI MAF engine that Im working on. I have a suspision that the ECM may be bad. I have a spare ECM out of a 90 Trans Am that was a 350 TPI Speed Density engine. The service number on the spare ECM is 01227730. If I swap the proms around will this computer work in the 305 MAF car? Thanks for the help.
P.S. If that will not work I can use the ECM out of my 88 L98 IROC as long as I switch the proms right?
Old Jun 11, 2008 | 10:50 AM
Pop45398's Avatar
Car: '91 RS
Engine: 355 on a stand
Axle/Gears: 3:42
Re: Will a SD ECM work in a MAF car?
Your PROM will not work in the '730 ECM but it will work in your 88 L98 ECM ('165 ECM).
The '730 has a very different pinout and an extra connector. Installing it in an 88 would require repinning the ECM connectors and a harness modification for a MAP sensor. It can be done but it is certainly not a drop-in.
Old Jun 11, 2008 | 10:54 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Thanks for the info, looks like its time to borrow from the IROC.
Old Jun 11, 2008 | 11:27 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
specialized
Jun 18, 2022 09:26 AM
NBrehm
Aug 25, 2015 11:49 PM
marcusaw
Aug 10, 2015 08:13 AM
MENINBLK
Aug 5, 2015 11:58 PM
