checked the codes
Old Jun 19, 2008 | 09:47 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
checked the codes
Well I read on here how to check the codes by jumping the last two terminals on the aldl. When I turned the key on it did what it was supposed to do, but the E. Fan was running?
Also is there a aldl usb connector that I could connect to my laptop to monitor stuff while the car is running? If so where would I get one? and any if I should know about them?
Old Jun 20, 2008 | 12:43 PM
Rebuildman's Avatar
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
Re: checked the codes
E. Fan? Cooling fans will come on with ecm in diagnostic mode. ALDL connection: I use pins stuck in plug and connect to my laptop via serial port. I have heard connecting through usb is possible but has issues, that was a while ago, problem may have been corrected. Check out Craig Moates website for all your datalogging needs. I believe he has a USB converter.
Old Jun 20, 2008 | 06:02 PM
Car: 86 Z28
Okay, I have to look into getting one of those, but would it work on my old laptop, 400mhz 256mb ram, i put xp pro on it though. Also where is the fuse to clear the codes after I retrieve them?
Old Jun 20, 2008 | 09:31 PM
Rebuildman's Avatar
Old laptops are fine, I use XP on mine with Tunerpro. Fuse should be in main fuse panel labeled ECM, check the wiring diagram for your car. Or just disconnect the battery.
Old Jun 20, 2008 | 09:54 PM
Car: 86 Z28
The fuse was right by the battery on the wheel well. How do you know which wires go where on the serial port?
Old Jun 21, 2008 | 08:17 AM
Rebuildman's Avatar
It's not a direct connection, there is a interface that needs to go between which you can build or buy. Go over to the prom tuning message board and check out the stickies at the top, you will find the required hardware needed to log data.
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
Out-Cast
Aug 17, 2015 10:57 AM
