Testing knock sensor
Old Jul 2, 2008 | 01:12 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Any way to test if the knock sensor is working?
Old Jul 2, 2008 | 04:14 PM
CaddyMan's Avatar
Car: 1990 Cadillac Fleetwood Brougham
Engine: Chevy 350 TBI with some goodies
Transmission: TH-7OO-R4, waiting for rebuild
Axle/Gears: Stock. Saving for 3.73 posi unit.
Re: Testing knock sensor
With the engine running, slap the block. I believe your idle should increase amd also your timing will advance. Someone will correct me if I am wrong. You may also want to try a forum search. There is something in there because I had an issue with mine.
Old Jul 2, 2008 | 04:50 PM
Ronny's Avatar
Should show up in a data log as retarded timing when you tap on block with a small ball peen hammer. My logs also show number of KC's seen and in what cells are occuring.
Old Jul 2, 2008 | 07:21 PM
Toehead's Avatar
Ok, I am not getting any knock counts.
How can I test to see whether it is the sensor or the ESC module.
Old Jul 2, 2008 | 07:56 PM
Toehead's Avatar
It's the sensor... Hooked up my trusty analog gauge to the output and hit the side of the motor with a hammer and nothing.
Did the same to my bro's car, and saw the needle go to zero.
Then swapped modules. Mine works on his as well, but neither works on mine. Looks like im looking for a new knock sensor.
Thanks guys
Edit-
Scratch that, some more testing revealed that I am a meathead and wired the module wrong when I built my harness. I had the power and ground switched. All better now, and I am getting knock retard as I should.
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
