ALDL not responding
Old Jul 13, 2008 | 08:17 AM
dholm's Avatar
Car: '88 Camaro IROC-Z
Engine: 350TPI
Transmission: TH700R4
ALDL not responding
Hi,
I recently bought this ALDL cable from TPI Parts and I believe it's based on the 2-transistor ALDL interface. I've just tried hooking up my laptop to the car using a PL-2303 USB<->RS-232 converter but I'm unable to get it to work with any applications and would like some help on how to proceed to locate the problem. I have an '88 Camaro 350 TPI with the 1227165 ECM (according to the label on it at least).
All the tests in ALDLTest v200 fail. (Both fast and extended)
When running TTS Datamaster (DM35x32) it says that it has connected a working cable but is unable to communicate with the PCM.
EFILive V4 reports:
37:44.754: Scanning for heartbeat and chatter frames...
37:44.754: Waiting for Aldl bus silence of at least 50ms...
37:44.805: Start reading frame
37:45.005: Com timeout: Expecting frame header byte
37:45.011: No chatter found
39:03.511: Opening COM3 8228,8,N,1
39:12.648: Check vehicle interface...
39:12.653: Waiting for Aldl bus silence of at least 50ms...
39:12.703: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
39:12.703: Start writing frame
39:12.703: Send: $FF,$55,$AC
39:12.704: Finished writing frame
39:12.704: Wait 10 ms after writing, before reading...
39:12.714: Start reading frame
39:12.814: Com timeout: Expecting frame header byte
39:12.825: No response from Max232
39:12.825: Retrying Max232 detection...
39:12.825: Waiting for Aldl bus silence of at least 50ms...
39:12.876: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
39:12.876: Start writing frame
39:12.876: Send: $FF,$55,$AC
39:12.876: Finished writing frame
39:12.876: Wait 10 ms after writing, before reading...
39:12.886: Start reading frame
39:12.986: Com timeout: Expecting frame header byte
39:13.001: No response from Max232
39:13.001: Retrying Max232 detection...
39:13.001: Waiting for Aldl bus silence of at least 50ms...
39:13.051: Requesting Max232 interface to acknowlege: $FF,$55,$AC...
39:13.051: Start writing frame
39:13.051: Send: $FF,$55,$AC
39:13.051: Finished writing frame
39:13.051: Wait 10 ms after writing, before reading...
39:13.061: Start reading frame
39:13.162: Com timeout: Expecting frame header byte
39:13.176: No response from Max232
39:13.176: Retrying Max232 detection...
39:13.176: Interface cannot be detected
39:13.184: Scanning for heartbeat and chatter frames...
39:13.184: Waiting for Aldl bus silence of at least 50ms...
39:13.234: Start reading frame
39:13.335: Com timeout: Expecting frame header byte
39:13.340: No chatter found
TunerPro RT simply says there is no cable connected.
I wanted to blame the ALDL cable first but since Datamaster said that it found a working cable I'm not sure anymore. I have checked the connection between the ALDL connector under the dash and the ECM and the wiring appears to be ok. Is there a simple way that I can rule out the ALDL part of the ECM isn't broken? I do not have easy access to an oscilloscope. :/
The car is running fine otherwise, except maybe once in every 10 times I start it when it idles very roughly which is what I wanted to debug using the ALDL cable. It is currently running on an ADS Superchip but I have the original one as well.
Old Jul 22, 2008 | 10:22 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ALDL not responding
Could always do the paperclip in ALDL connector thingy to bring up the codes / Service engine light to confirm wiring / ECM correct.
"PL-2303 USB<->RS-232 converter "
Lots of people have reported problems using a ext serial / USB adapter.
I have a ALDL /USB cable with serial / USB software that works fine with both TP and Datamaster.
However Datamaster will often decide not to connect first few times.
Can you borrow a old laptop with a serial port to confirm cable / connection is working correctly
Old Jul 23, 2008 | 03:15 AM
dholm's Avatar
Engine: 350TPI
After some recommendations on my local Camaro forum I bought a slightly more expensive cable which has a built in USB interface and it works perfectly.
xodus2002
Jul 17, 2020 09:08 AM
1992Z28!
Nov 19, 2015 07:33 AM
L98GTA87
Oct 19, 2015 10:43 PM
greenyone
Sep 8, 2015 08:41 PM
