my 7730 EMC crapped out, unbelievably
Old Jul 22, 2008 | 02:27 AM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
I went to start my car to drive home, and it just ran like a pig, had to keep one foot on the gas just to keep it from dieing, wouldn't idle at all. but it still could drive, although reeked of fuel vapors (very rich), while driving home, I noticed the speedometer/odometer wasn't registering, so I figured the VSS crapped out. when I got it home, I hooked up my Datamaster/laptop, and it wouldn't synch up. then did the ALDL flashing light thing, and got codes 12, 14, 42, & 45. 14 is the temp sensor, 42 was the EST, and 45 was the O2. I was surprised I didn't get code 24 for the VSS. started trouble-shooting with the temp sensor & wiring (easiest), and which all checked out okay, so swapped out the ECM & memcal, and car started right up, very fine. luckily I had a spare ECM stashed away from ebay.
I figure I got the car home in limp-home mode, woulda probably been better if I had kept the factory 22# injectors instead of biggie-sizing with 30#, at least then the memcal limp-home would've been in the ball-park. maybe I should swap back to the 22#'s since I don't think I've ever thoroughly exercised the 30#'ers. food for thought.
Bohemian
Aug 15, 2017 05:11 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Jonas Earl
Sep 27, 2015 07:39 AM
BWilcox
Sep 20, 2015 12:19 PM
Racerx974
Sep 19, 2015 10:16 AM
