Injector Resistance?
Old Jul 29, 2008 | 04:01 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
So i measured the resistance on all 8 of my injectors and found the following:
Injector# Resistance in Ohms
1 17.1
2 16.8
3 16.8
4 17.1
5 16.8
6 16.8
7 16.8
8 16.8
I know the previous owner said something about swapping out for bigger injectors.
The questions are:
Could this be a problem having that variance on 1 & 4???
Are these values around the normal range?
Old Jul 30, 2008 | 08:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Injector Resistance?
For Multec's they are in the proper range. Which is about 16 ohms (plus the DVM lead resistance). You may want to pull some numbers off of an injector and find out what they really are.
RBob.
Old Jul 30, 2008 | 08:07 AM
shingadaddy's Avatar
Car: 91 Z.
Engine: 5.7 TPI
Manual says 10 ohms or more. Mine new ones all measure around 16. I wouldn't be concerned with the values you have. They appear to be good to me. My old ones that were still good were 16.5 or so. The ones I considered "BAD" were 12, 7.5, and 2 at 5 ohms. These low-value ones load the injector driver so much that it can't control the other injectors for good mixture control.
Old Jul 30, 2008 | 09:33 AM
boldguy's Avatar
Car: 1992 Z28
Thanks for the quick replies!
so once i pull the number where do i look for it on the internet? Is there a site or do i just search it?
And last time i pulled the number off of the shoulder and there were (if memory serves) 3 groups of numbers...
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
