why does some pple only run in open loop?
Old Aug 16, 2008 | 12:06 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
why does some pple only run in open loop? isnt closed loop the best cuz u got your o2 sensor?
Old Aug 16, 2008 | 12:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: why does some pple only run in open loop?
With vehicles built prior to 1974 (US) and some export vehicles there isn't a catalytic converter. No cat-con, no need for closed loop. Running at stoich isn't always the best.
RBob.
Old Aug 16, 2008 | 02:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i like open loop cuz its abit easier to tune for me. i could run closed loop and have been doing so for awhile but there was a startup idle issue i couldnt figure out and i stopped trying.
open loop is easier to tune on motors with bigger cams with overlap that screw up the o2 sensor readings. you can tweak the o2 readings to work for alot of cases but some its just better to try open loop
Frozer!!!
Jan 19, 2024 04:55 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Jae992
Aug 27, 2015 09:07 AM
BurlyChev
Aug 16, 2015 09:08 PM
