VATS bypass questions
Old Oct 22, 2008 | 02:36 PM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
Well first off I wasnt sure whether i should have put this ? in here or under the LT1 forum, but anywase I put it in both haha.... My ? deals with the VATS bypass on the LT1 ECU. It turns out when I sent out my compter to be burnt for the specifications of my engine they forgot to burn out the vats so now I'm stuck with a vehicle that will run for only 4 seconds and I was wondering if anyone would know which wires/pinouts on the connectors to the computer are the ones for the vats??? My plan was to locate those wires and splice resisters where neccessary. My other question was I heard of a piece you can purchase that plugs between the ECU connector and the ECU itself that is a VATS bypass module? has anyone else heard of this... I'm going to call summit/jegs and ask about it but I was just wondering if anyone knew of it or used it.
Thanks for the help
Old Oct 26, 2008 | 12:31 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: VATS bypass questions
i can bypass the 3rd gens not sure on the 4ths but u should see a white thin wire with 2 orange ones inside of it coming down from the column near your knee pad unplug it and u can just read the resitance off of it and get a resitor for it but u have to get the EXACT resitance or it wont work
Old Oct 26, 2008 | 04:53 PM
86LT1's Avatar
Engine: 357 LTx
I purchased a vats bypass module and wired that in, its running now but now I have some other things to tweak. Thanks for the help
Old Oct 26, 2008 | 05:00 PM
tom86iroc's Avatar
Car: 1986 iroc
no problem good luck
Glowsock
Jul 24, 2025 03:15 PM
stalkier
Dec 6, 2015 11:25 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
