about megasquirt
Old Dec 6, 2008 | 07:27 PM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
Transmission: 4sp auto
Axle/Gears: stock for now
about megasquirt
Im thinking with the mods ive made to my 88 iroc z that a MS might be worth the $ a chip from fast is around 350 $ and a mega is around 400$ and if i do somthing later ill need a new chip( more money) and ms can be changed my ? is how would instal it does it just plug in to the ecm or in place of the ecm or do i have to wire it in to all the sencers???? any help would be GREAT thanks
Old Dec 31, 2008 | 11:54 AM
HydraQuest's Avatar
Car: '87 Pontiac Trans AM
Engine: 350 CID STS Turbocharged
Transmission: T56 6-Speed SPEC Stage II
Re: about megasquirt
Phew, that is a loaded question.
No, MS is not a direct plug and play ECM. However, it is well worth it. If you have the drive and the skills, do it. However, be warned, it took me three weeks the first time to wire mine up. I used to stock wiring and just adapted it to work with MS. Mistake. Use the wire kit from DIYAutoTune.com and the relay box. Much easier and more reliable. It only took me three days to rewire it with that kit. You can use all the stock sensors, I however, did buy all new ones just to eliminate them as a source of problems later.
It scared the crap out of me when I hit the key the first time and it fired to life as if pissed off that I had put it through that torture. I did not expect it to just fire right up. I expected a fight.
MS is not easy to assemble. If you are not skilled in soldering, buy a pre-assembled one. It look me longer to find all my bad solder joints than it took to re-wire the car the second time.
I will give one word of advice to anyone wanting to install MS, patients. Do not rush any part of the install, check and double check, then check again.
I will install another one in my '68 Firebird convertible project. I will most likely install one in my wife's Jaguar too.
Feel free to PM any questions you have, I will try to answer to the best of my ability.
Thirim
Aug 13, 2015 03:09 PM
mhaskell
Apr 26, 2008 01:01 AM
daves12secV6
Nov 20, 2006 09:05 PM
mhaskell
Alternative Port EFI Intakes
Mar 20, 2006 11:30 AM
86bird_28v6_5spd_ramair
Aftermarket Product Review
Oct 13, 2001 09:57 PM
