'92 5.7 TPI won't start
Old Dec 21, 2008 | 09:40 PM
wlkdwlk's Avatar
Car: 1991 Z28 5.7 TPI
Engine: 5.7 TPI
Transmission: 700 R4
My '92 5.7 TPI sometimes will not crank. I have power to all the accessories but not to the starter. I'm not familiar with the VATS technology but have a funny feeling that this may be the root of my problem. Again, the problem is intermittent, happens when cold, hot without any perceivable cause. Any help would be appreciated. The car also has over 160,000 miles on the odometer.
Old Dec 22, 2008 | 10:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: '92 5.7 TPI won't start
To check if it is a VATs issue there is a Security lamp in the dash. At key-on, engine-off the light should turn on for 2 seconds then turn off.
If the light turns on and stays on then the VATs module isn't reading the key correctly. In this case the engine won't start.
Most issues with VATs is either the key gets dirty (little chip like piece in the upper portion of the key). Or the wires from the lock cylinder start to break.
RBob.
Frozer!!!
Jan 19, 2024 04:55 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
