V-6 memcal w/ a 350 Piggy Back?
Car: Current project is 70 Monte Carlo
Engine: 350 TPI (SD)
Transmission: 200-4R
Axle/Gears: 3:73, 12 bolt Limited Slip
Maybe a dumb question... I have a memcal from 6 cylinder 92 Camaro. And I am a retro-fitting a TPI into my 70 Monte with a 350. Can I use this memcal with a piggy back type chip calibrated for my engine? Or just need to bite the bullet and get the right one, then get it custom tuned?
Car: check
Engine: check
Transmission: check
Re: V-6 memcal w/ a 350 Piggy Back?
The V6 MEMCAL won't work with an 8-cylinder unless modified. In stock form the cylinder select will be incorrect. The wrong injector firing rate and a SES light will result.
Need to change the cylinder select by grounding one of the NETRES pins. I think it is pin 56 on the MEMCAL. But that is from memory, so it may not be the right pin.
RBob.
RBob.
Thanks. I did a bit more research on the mod required. Still not sure I'm into that, and it looks like I should use one from a 4.3 since it has the same bore/stroke. The one I got is from a 3.1. Looks like it would have a lot of problems with the ESC.
Then thought maybe use an Ostrich, but same problem. Need the correct memcal... guess I'll keep searching the junk yards or fork out the $200 + for a custom one to start with, then learn more about tuning and go from there.
