Prom Fuel Injector algorythim question
Old Mar 4, 2009 | 09:19 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Transmission: 700R4 B&M Hammer Shifter
Axle/Gears: Stock Posi
Ok so back ground info..
new 383 300 miles on it with TPI ... lost the ECM (not pulsing the injector ground to activate.
Still was running 305 injectors and ECM/PROM as a stop gap for a short while.
new 350 injectors on their way as we speak.
I have a new 350 hypertech chip ( I know I could probably burn one eventually)....
My question is I was under the impression from the supplier and per hypertechs intructions on the net that they were NOT an interceptor module (piggyback) module. Therfore, I could replace my 305 PROM with thier chip. Much to my dismay I got the chip today and it IS an intercept chip. However, reading thier information... it say thier programing overides the stock fuel and ignition tables. So.....
In theory... couldn't you run a 305 EPROM with a 350 Hypertech module and it would push timming and fuel injector PWM as it was a 350 prom?
Scott
Old Mar 5, 2009 | 07:55 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Re: Prom Fuel Injector algorythim question
Oh come on I know there are some super prom guys/gals out there!
Old Mar 6, 2009 | 07:00 PM
lucky14's Avatar
Car: 91 Z28
Engine: 383 TPI
Check out my other posts in DIY Prom... turns out that you can run the 305 memcal chip with the 350 TPI Hypertech and 350 injectors and be ok... according to the gurus... Whoohoo
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
djmarch
Aug 11, 2015 10:22 AM
