16197427 conversion help
I was reading about the conversion for this ecm and I have a couple of questions.
1. What are the pinouts for the electric high and low speed fan for the maf version?
2. can the maf version run a 700r4 or just a 4l60e?
3. can I use a 3100 fwd car maf on my 305?
4. The output pin for the maf goes into the vss input on the pcm, will my speedo still work or does that get relocated?
I may have a couple more questions. I have this wired up running my 305 right now in stock form with the 700r4. I was thinking of converting over to the maf version to run dual fans and to have a maf sensor.
Car: check
Engine: check
Transmission: check
Re: 16197427 conversion help
There is a long thread on the DIY_PROM board about Dimented's $0D MAF setup. I think what you are looking for is in that thread.
This isn't the thread I was thinking of,. However it has locks to the other good threads:
https://www.thirdgen.org/forums/diy-...rsion-maf.html
RBob.
RBob.
2012sergen11
Oct 13, 2015 07:38 PM
