INT related Question?
Old Mar 11, 2009 | 07:18 PM
ysr175's Avatar
So i was going through some more settings in turner pro when i came across INT Rich and lean values VS' Map, with the simulated NB output from the WB the Lean and Rich Points wont change with engine load any more so all these should be the same. Am i corect on this?
Also INT Delay Mult vs O2 error should all these be the same as well?
Old Mar 12, 2009 | 07:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: INT related Question?
You shouldn't need to change the rich/lean/mean O2 switching tables. Although they may be changed a bit for different results. From what I've been able to tell GM set them up to match the type of cat-con that was equip'd on teh vehicles: 2-way vs 3-way.
There is more informaiton on how this works on the DIY_PROM board, sticky's, Tuning Guide Book, Chap. 5, '8063/'8746/'7747 ECM, Fueling Logic.
RBob.
Thirdgen89GTA
Aug 25, 2015 06:40 PM
CORV3TT3
Aug 23, 2015 11:26 AM
86IROC112
Aug 21, 2015 07:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
