help! please!
Old Apr 9, 2009 | 01:45 PM
bigkbkid's Avatar
help! please!
I have a 92 firebird that i run on the dirt track. Sat. i had a racin incident and now i have no injector pulse. I chaned the ecm and it still no good. so i bought a VATS bypass (bakerelectronix). the directions are not that great.
Where Do I Hook It Up At? and is there anything else that might make the injectors quit pulsing?
Old Apr 9, 2009 | 03:57 PM
Ronny's Avatar
Re: help! please!
fuse? there are two inj 1 and inj 2. I think ECU has a seperate one as well.
Old Apr 9, 2009 | 05:17 PM
bigkbkid's Avatar
Re: help! please!
I have checked all the fuses. the car will run if you pour gas in the throttle body. still trying out this VATS bypass thing.
Old Apr 10, 2009 | 12:55 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: help! please!
What kind of incedent? The wiring for the ECM doens't go through the firewall but out the side beghind the fender and then into the engine compartment.
So its sort of exposed.
Old Apr 10, 2009 | 11:03 AM
bigkbkid's Avatar
Re: help! please!
Gumby- i have moved my harness from the inner fender to through the firewall for that reason. thanks
i changed the chip in the ecm and the injectors pulse now but it seems like the tbi fuel return is hung open and the fuel is blowing by the injectors.
Old Apr 20, 2009 | 03:32 PM
johnrstuch's Avatar
Car: 89 Trans am GTA
Axle/Gears: not sure
Re: help! please!
try checking your distributor,that is where your pulse starts at, on
newer cars with distributorless ignition they get pulse from crank
position sensor.
Old Apr 21, 2009 | 11:27 AM
bigkbkid's Avatar
Re: help! please!
thank you johnrstuch. i narrowed it down to the module in the distributor. hopefully this fixes it.
