Can't pull trouble codes, normal code 12 does not flash
Old Apr 2, 2009 | 02:01 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Can't pull trouble codes, normal code 12 that show the system is working will not flash. Light just stays lite, no flashing.
I know how to pull codes, I got the jumper key.
Have pulled codes before.
Problem is on a cold start I lose power sometimes, like spark.
will back fire through intake but give it some gas and it gone.
Like something is going in and out but can't pull the codes to check.
As when it does run right its runs great.
Old Apr 2, 2009 | 05:36 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Can't pull trouble codes, normal code 12 does not flash
pulled ecm from under dash, wiggled all the wires n checked connection there and under hood.
If it start funny and I can get the rpms over 2000 playing with the gas pedal it will idle fine for a few, then it will for no reason start to sputter and die if you don't give it gas and rev it up.
Found this thread but I wasn't doing anytihng like that.
Hate to start replacing parts for no reason.
https://www.thirdgen.org/forums/dfi-...ght-stays.html
Old Apr 2, 2009 | 05:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I know its not fuel pump and stuff, all been replaced recentaly.
Now it had done that in the past, say dozen times a year but all I would do is shut the car off and coast for a bit, dump clutch and fire it back up and it would be fine.
Always seemed if I turned the key on and off 2-3 times before I started it, it would keep it from doing that. And never did it once it was warm or had been driven.
But now I can't make it go away doing them two things.
Old Apr 3, 2009 | 01:44 PM
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
I know I had trouble pulling codes on my '87 with the jumper method. I bought an ALDL cable and installed the free software. Best money I have spent so far on the car. You can access everything; see codes that have been tripped, monitor engine parameters, etc. Very helpful.
Old Apr 3, 2009 | 09:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Only thing I had touched before it did this was the MAF and the air temp sensor, MAF was not unhooked just moved around, air temp sensor in the intake was unplugged in and out a few times.
Old Apr 4, 2009 | 02:26 PM
87GTAj's Avatar
Engine: 5.7L TPI
Are you trying to get advice on solving your problem, or simply pulling codes? Because your title seems to imply you want to pull codes to help solve your problem. The ALDL cable will do just that for you. It will let you see any codes that have been tripped.
Old Apr 4, 2009 | 05:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well I have gotten no where, did check fuses.
checking the juice between a/b shows 5 volts
I built the cable using this one
http://viragotechforum.com/phpBB/files/aldl_adap.jpg
I get nothing from the aldl program, is ther some trick to it?
Or just plug it in and itshould gather error codes and read data???
Still starts funny but give it some gas and it idles n revs up fine now.
Is there a way to tap the aldl cable in near the computer to get direct access and rule out wiring between there and the plug???
Old Apr 4, 2009 | 11:36 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
rockauto to the rescue maybe, looking up a reman ECM $72 they got a list of PDF files including a service bulletin on things to check first.
Constant or Intermittent Engine Light w/No Codes Stored (GM), Stalling w/No Codes Set (All Makes), Check Engine Light Goes Out When Assessing Codes (GM), Various Drivability Problems (All Makes)
http://www.cardone.com/english/club/...%2077-0008.pdf
Also the feature of the reman ECM they sell are as followed.
"Original quad drivers that are not short-protected are removed and replaced with short-protected quad drivers. - Corrects an O.E. design flaw and allows vehicle owner to replace a solenoid instead of the entire ECM the next time a short occurs."
As the car did have a code 33, 54 all its life.
Which is FP, FP relay, oil switch, open or short circuit, defective ECM.
poor connection, open or short circuit, bad MAF or defective ECM
And since it has ran great its whole life I have totally ignored them codes as trying to fix them by replacing parts cept the ECM didn't help any.
And chalked it up the a dumb 80s computer.And since it has ran great its whole life I have totally ignored them codes.
And chalked it up the a dump computer.
Old Apr 5, 2009 | 12:12 PM
87GTAj's Avatar
Engine: 5.7L TPI
First thing would be to make sure your cable works - not doubting the link's validity, but that's a possibility. Second, the program I use is WinALDL, and with the car in run/acc, it gathers real time data about the engine, you can monitor all of the possible codes and check for them to be tripped. Lastly, in WinALDL and some other programs, you need to choose the ECM that matches your car's ECM - very important step - . Without the correct ECM, it won't read a thing.
Regarding tapping in closer to the ECM, I don't know for sure, but if you find a schematic explaining where the pins connect to the ECM (specific pin locations) you should be able to attach your cable there as well.
Old Apr 5, 2009 | 01:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
yep Im using winaldl, all setting are right, double n triple check cable while building, it will not gather any data, program does nothing. little dash board thing in it don't show rpm or nothing.
Old Apr 5, 2009 | 02:56 PM
87GTAj's Avatar
Engine: 5.7L TPI
Well, as long as your computer is set up to read whichever COM port you are connecting to, it may be the ECM. I know WinALDL has multiple COM port options, and you have to have that set correctly for it to work.
Old Apr 21, 2009 | 01:31 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
It’s Alive!!!!!!
Thank the lord.
The ECM replacement was a total shot in the dark.
Did have a few hiccups at first.
Had to wire my fuel pump back up as it was on a switch.
[Computer turning it on should of been a clue]
I was then able to get the 2nd ALDL cable I built working and was able to do some data logging.
Old Apr 21, 2009 | 01:45 PM
firstfirebird's Avatar
Cool!
I was about to tell you I had the dataloggin problem in a car recently and tapped in at the ECM connection to get a stream, but glad you found it
Old Apr 21, 2009 | 02:02 PM
87GTAj's Avatar
Engine: 5.7L TPI
It’s Alive!!!!!!
Glad to hear you got it working now.
chazman
Aug 28, 2018 03:25 PM
CORV3TT3
Aug 23, 2015 11:26 AM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
