ecm and factory tach
Old Apr 22, 2009 | 11:30 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
does anyone know on the 87 maf type tpi if the ecm needs the factory tach hooked up or does the ecm read rpm internally???I hooked up an aftermaket tach and left my factory one unhooked and was wondering if i should hook it back up or not.Also i have the autogage autometer tach and it seems to be reading to low has anyone had to use that adapter and it made it read right id hate to spend 40 bucks and find out i just need to hook it to a differant place or something i have an msd 6 ignition on it to and have the tach hooked to the spot on it
Old Apr 22, 2009 | 08:16 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: ecm and factory tach
The ECM reads the RPM via the 4-wire connector to the ignition module. The tach comes off the coil-. So no problem with an aftermarket tach and leaving the stock tach disconnected.
RBob.
Old Apr 22, 2009 | 08:18 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Beat me to it...
Old Apr 23, 2009 | 08:40 AM
Car: 87 iroc z
Engine: 358 tpi
thanks alot man
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
skeltor
Feb 2, 2016 10:37 AM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 8, 2015 11:28 PM
