The Oh So Great Commander 950
Old May 1, 2009 | 10:05 PM
Vice04's Avatar
Car: 84 Monte
Engine: 355 Chevy HSR
Axle/Gears: 3.90 Ford 9"
So, after four years of talk, i decided it was finally time to stop relying on the 120 shot of nitrous on my old TBI 305 in my 92 Camaro and build a TPI 355. That's where my question comes in. Does the 950 replace the old ECM all together, running the gauges and everything? Or do I have to retain the stock computer for gauges, fan, etc?
I would call holley and ask, but it took all of $3200, 2 months, a million phone calls and an act of god to get it, so i would rather ask people with experiance anyway.
Old May 2, 2009 | 08:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: The Oh So Great Commander 950
The stock TBI ECM ran the fuel pump via the relay. The speedo, cruise, and VSS signal to the ECM comes from a 4-out buffer box. So leave that in place. The fan was/is controlled by a switch in the cylinder head. Between cyl's 6 & 8.
That's about it for external controls via the ECM.
RBob.
Old May 2, 2009 | 09:27 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Your gauges don't run through thr ECM. U can throw away the old ECM when you go to the 950. The 950 can control the fan if you want. You can also wire in the knock sensor and esc if you want to. The 950 does not use the vss signal at all.
Old May 2, 2009 | 01:26 PM
Vice04's Avatar
Car: 84 Monte
Thanks, I was a little worried about spending another grand on gauges in one drop. I'll go to new gauges eventually, just not right now.
J-money
Jan 4, 2019 09:45 AM
tglennon11
Sep 23, 2015 05:30 PM
Jk_Under
Sep 8, 2015 08:13 AM
scotrans am
Sep 5, 2015 04:26 AM
tgp1990
Sep 4, 2015 06:24 AM
