About to order Ostrich
Old May 8, 2009 | 04:21 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
I have decided after a long debate I want to use an Ostrich 2 to tune my truck, it has a 16197427 PCM and Moates doesnt list that one but I have found quite a few people of FSC and the moates forums that have said they used it and it worked. Before I order I just want to confirm all I need other than a program (Tunerpro RT) is the unit and the G1 adapter.
Old May 8, 2009 | 06:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: About to order Ostrich
Yep, G1, Ostrich, .XDf for the proper MaskId ($0D?), .ADS for for same, and an ALDL cable.
Laptop with USB port. If no serial port then need a USB ALDL cable. Note that the Ostrich should be backed up with a PROM. So add the Burn2 and some flash chips.
That should do it. Let me know if it doesn't.
Oh, maybe the HDR1 to read your stock BIN for a starting point.
RBob.
Old May 8, 2009 | 07:17 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
I can the the mask and the BIN from Moates right?
Do I have to datalog to the same laptop as I'm using to tune? I can datalog with my OTC scanner and look back at that?
Fireslash
Apr 11, 2016 06:43 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
Bigold4x4
Sep 28, 2015 05:21 PM
