Can I connect an SGI5 box directly to my speedometer?
Old May 17, 2009 | 04:44 AM
1bdbrd's Avatar
Car: 1991 Trans Am
In the process of swapping to a t56 and will obviously be using the Dakota Digital box during the swap to work my stock speedometer. However, shortly after swapping the t56 in, I plan on running a megasquirt setup instead of the stock ecm. The MS does not have an input or output for a VSS so I am wondering if I can connect the SGI5 box straight to the speedometer instead? I don't see why this wouldn't work as long as I programmed the box correctly right?
What am I missing here?
I posted that in the electronics and the transmission board and was told to try here, so mods that's why there are 3 different posts about this.
Please someone tell me if this will work or not...
BRoss99
Aug 10, 2025 05:08 PM
camaro11j
Sep 19, 2018 08:49 AM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
marcusaw
Aug 10, 2015 08:13 AM
