Running OE 96+ vortec induction with 7427
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
I am doing research for the MPFI conversion using my 7427 PCM. If I use the 96 vortec CPI injector what mods are needed to the PCM to drive that injector?
Car: check
Engine: check
Transmission: check
Re: driving PFI injectors with 7427
Depends upon the resistance of the injectors as to whether anything or what needs to be done. If using saturated injectors just run jumpers across the sense resistors.
RBob.
RBob.
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Thanks RBob I found that on FSC though.
Is the jumper mod needed to run the CPI injector from the vortec intake or not? How would I do that? I'm not dead set on using it but I picked it up complete for $15 so I couldnt pass it up, plus I didnt even have to pull it!
Is there a true PFI OEM intake setup for vortec heads or only CPI?
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
