quick question for a tbi ecu
Old Jun 15, 2009 | 01:21 PM
dollarbill425's Avatar
Car: 89 Camaro RS
I have done the 305 to 350 swap years ago but never finished the esc, knock sensor or ecm part until now. I already have the 350 injectors in, just put the esc and knock sensor in, now for the computer, I know I can use one from a 350 caprice, but will a say 89 silverado 350 tbi computer work?
Old Jun 15, 2009 | 01:50 PM
Ronny's Avatar
Re: quick question for a tbi ecu
Why not use the ECU you have in car now? Al you need is a "corrected" chip aka .bin.
Old Jun 15, 2009 | 02:50 PM
Car: 89 Camaro RS
sorry I mean the prom chip, I ordered an ALDL cable and it came with some software, I haven't got a chance to use it yet. I was wondering if I just swapped the prom over would it have the correct values or still be off in the bin files?
Old Jun 15, 2009 | 03:02 PM
Ronny's Avatar
Having the 350 injectors will help out. Adding a auto trans cop car chip is your first choice. I assume you have auto trans. Other option is to have one custom made. tbichips.com comes to mind. Another option is to get into prom burning and use your stock 305 chip as basis. Just modify that stock .bin as needed. Stock 305.bin should allow car to run with the larger injectors.
Old Jun 15, 2009 | 03:25 PM
Car: 89 Camaro RS
Yeah my buddy has all the stuff to burn chips and what not I was just wondering, I know its running real fat right now and if I stomp the pedal from a stop it gags and stalls...
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
