egr go away please!!!
Old Jun 23, 2009 | 09:15 PM
85t/alover's Avatar
Car: 1998 Camaro Z28
Transmission: 4L60E. Right now.
Axle/Gears: 10 bolt, Torsion diff, 3.73 gears.
i eliminated the emissions stuff in my 91 tpi formula. now tonight, a week after i disconnected everything, i threw a code 32. how do u keep the comp from throwing codes for removed emissions equipment?
Old Jun 24, 2009 | 02:39 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: egr go away please!!!
you need to modify prom by removing EGR flag + change temp. when EGR is being turned on.
best regards
Old Jun 25, 2009 | 06:40 AM
85t/alover's Avatar
i decided to keep the egr since i read it is seperate from everything else. problem is the wire coming straight out of the egr is not hooked up and i can't find where it plugs in.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
