Wich software to choose?
Old Jul 9, 2009 | 08:13 AM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Hi there..
I need some help with datalogging my ECM on my 87 Camaro.
I have bought a USB cable from www.aldlcable.com and need a software program to use.
I have tried with a few programs that I found on the internett such as TTS datamaster but I can't make none of them work.
Need help here...Serious help. I have measure the voltage on the M port at the ALDL connector when ignition is set to RUN and there is regulated voltage between 3 and 5 volts so the ECM is sending DATA.
I connect the cable but can't make any program work...Please help me out here...
Old Jul 9, 2009 | 10:58 AM
Ronny's Avatar
Re: Wich software to choose?
You could try this... http://winaldl.joby.se/aldldata.htm
your vehicle is supported. I would suggest most of us started with this program for datalogging. I believe the cables suggestions are also listed on site.
Old Jul 9, 2009 | 11:29 AM
Thanks a lot...I will try that tomorrow...I also have to change the ECM output signal to Pin E and not Pin M as it is on my ALDL connector right now.
Have you tried WINALDL yourself?
Old Jul 9, 2009 | 11:30 AM
Ronny's Avatar
Yes winALDL is what we started with for datalogging. works well.
Old Jul 11, 2009 | 02:33 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
WinALDL is from what I hear a good one, Datamaster is $100 but from what I have saw looks to be a great one, thats the program my local dyno guy uses for OBD1 GM's.
Did you try TPRT? I use that but a different cable.
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
Deemax
Sep 12, 2015 06:53 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86camaroman201
Aug 19, 2015 04:52 PM
