Half way?!?!?!
Old Jul 11, 2009 | 08:00 AM
89F Body's Avatar
Car: 89 z
Engine: 96 350 HSR vortec
Transmission: 700R4 24-2800 BDR stall
Axle/Gears: 9 bolt disc posi w/3.45
Half way?!?!?!
Yeah so I got that issue figured out timing was wrong,oops.So now it runs but only on the even cyls. and and I know the injectors have ground and power but guess ill triple check.Any ideas, if new chip was in backward it wouldnt run at all right?
Old Jul 11, 2009 | 10:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Half way?!?!?!
It will still run with the chip in backwards. In limp mode, but it'll run.
TPI set ups have two injector fuses. Check to see if one has blown (INJ1 and INJ2).
RBob.
Old Jul 11, 2009 | 02:30 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Re: Half way?!?!?!
Do you not have noid lights to test? You know you can just use a regular 12v automotive light bulb if you dont have a set.
Old Jul 11, 2009 | 04:20 PM
89F Body's Avatar
Car: 89 z
Re: Half way?!?!?!
noid light does not light up the signal is not strong enough I wonder if my batt is to dead?And I was pretty sure to check fuses I dont think anything was blown.I pin tested the ECM, NO signal form there.....?!?!on odd cyls. I mean.
A1, A4, A5, A6 ASE's
Old Jul 11, 2009 | 05:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Half way?!?!?!
If this is an '89 TPI MAF setup, there is only one injector driver. So if one bank shows a weak ground then it is either the wire or the pin to the ECM harness connector. Or the trace inside the ECM fried.
RBob.
Old Jul 12, 2009 | 11:49 AM
89F Body's Avatar
Car: 89 z
Re: Half way?!?!?!
Yeah its 89 and Im kinda thinkin ECM in fried.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
FormulasOnly
Jul 23, 2018 08:47 AM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
drumstixer
Sep 29, 2015 03:02 PM
Damon
Sep 26, 2015 04:29 PM
