what would cause this? datalog errors, running lean.
Old Jul 18, 2009 | 12:07 AM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
everything has been replaced, think of it as a new car. heated O2. 165 ecm with 1989 bin
my car's running way lean, BLM around 155-160.
when I datalog using winALDL, the little box at the top flashes red with low numbers with an occasional "green 25".
My O2 reading will vary from .004,.45,.800 at idle and with throttle. The sound of the engine at idle sounds even, with a slight but not full miss in a cylinder or 2(assume from it being lean).
would a bad ECM cause this? I had the EGR temp switch wire plugged into the O2 sensor on accident resulting in voltage being fed up that wire wich shouldn't have.
I have no way of know what caused this because I just built the car. It isn't like "it was running, and then this happened."
Old Jul 18, 2009 | 12:19 AM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Re: what would cause this? datalog errors, running lean.
also, no thrown diagnostic codes and the car idle hunts at startup when cold. 500-1500rpm.
Old Jul 23, 2009 | 10:07 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Is it actually lean though?
Old Jul 24, 2009 | 08:32 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
I think so, I don't know what other thing to go by than the BLM. The fuel pressure is turned up a couple psi over stock and turning it up to around 48 psi doesn't change the way it runs.
Old Aug 21, 2009 | 07:47 PM
buwamd's Avatar
Car: 84 v6 camaro
Engine: 355 tpi
I don't know if you are running headers but one way I check for rich lean is header temperature, get a hand held lazer temp meter and point it at the header, if the temp is over 400 degrees its probably lean. you can also check for problems this way for each individual cylinder. hope this helps good luck
Old Aug 25, 2009 | 09:29 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
it was the fuel pump, it had pressure but must have not had "flow". The fuel pump crapped out 500 miles later and the new pump fixed the problem.
The $200 "performance" fuel pump had 3000 miles on it. Walsbro. needless to say I'm $200 pissed
Fast355
Dec 2, 2016 06:33 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ezobens
Aug 19, 2015 10:29 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
