ECM Swap
Old Aug 13, 2009 | 07:49 PM
tonygia's Avatar
ECM Swap
I have a 1990 Firebird, Trans Am, GTA. In the last 7 years it has been going through some major changes. Generally, I have converted it from a 5.0L automatic to a 5.7L, 6-speed. The overhaul is almost complete, however, I have run into a problem with the ECU. The current ECU has an Hypertech chip installed in it. I do not know what the characteristics of this chip is as it came with the car when I bought it. Needless to say, this chip does not like the 5.7L engine at all. I can start the car but the cold idle is rough and the hot idle is rougher. I am considering replacing the existing OBD1 with an OBDII ECU which would allow me to program the parameters or even replacing the existing ECU with a stand-alone ECU. I am not sure which is the best method and was wondering if anyone can provide some background to either of these options.
Old Aug 13, 2009 | 08:55 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: ECM Swap
you didn't specify what fuel system...then maybe i can help
AussiePr0nCar
Mar 6, 2020 04:04 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
