tpi parts programming service question
Old Sep 15, 2009 | 11:36 PM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
I bought one of these http://www.tpiparts.net/inc/sdetail/657 for a car i am building that hasn't ran b4 and was wondering if i use this chip do i have to do something else as well to bypass the vats or is this adapter a standalone modification
Old Sep 22, 2009 | 01:31 AM
Iroczracer's Avatar
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
Re: tpi parts programming service question
From what I could see it appears to be a programmed chip, if you requested vats to be disabled it will.. It looks like the same socket and chip that Moate's sells.
Old Sep 22, 2009 | 11:17 PM
Car: CAMARO RS
hmm its weird because the engine wont turn unless i bypass the starter enable relay does anyone know why that could be?
Old Sep 23, 2009 | 01:24 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
I dont think VATS disables cranking all together but I dont know how it works. Are you sure the neutral safety/PRN isn't giving you the problem?
Old Sep 23, 2009 | 10:45 PM
Car: CAMARO RS
well the car and the dash are for a stick and the car does have a stick but the prom is from an auto could that be the problem? cus i dont get any spark or fuel. but i think the pump is bad
Old Sep 24, 2009 | 04:24 AM
Iroczracer's Avatar
Shortly after I purchased my 89 IROC, it started having intermittent starting problems.. Traced it down to worn key and contacts in the switch it' self, it would not crank at all.. Removed the two wires going to the switch, soldered in a transistor from Radio Shack, and has had no further problems..
Old Sep 24, 2009 | 04:35 AM
Iroczracer's Avatar
I'm not sure on the prom, it may just throw a code. Was the car a manual from the factory or auto.. Can you hear the fuel pump run when you first turn the key on??
Old Sep 25, 2009 | 12:03 AM
Car: CAMARO RS
the cars body was a manual from the factory but the engine wiring harness and the prom are for an automatic this car has been completely redone it has a firebird dash it used to be a v6 and it now has all disc brakes and posi traction so now that it is all together i want to drive it real bad
Old Sep 25, 2009 | 12:06 AM
Car: CAMARO RS
i also have a transistor in those wires but it still wont start
Old Sep 30, 2009 | 01:20 PM
Car: CAMARO RS
bump
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
