Code 44 after replacement thermostat..
Old Oct 10, 2009 | 03:50 PM
rockstar08's Avatar
Car: IROC-Z
Hi,
I've just replaced the missing thermostat in my 350TPI '90 Camaro. The temp gage reads a normal 200-230 now. However A cruise around the block gave me hesitation problems when accelerating and it died once.
After checking the flash codes, I found a code 44. Which suggests a faulty O2 sensor reporting lean.
Is there a procedure to test the O2 sensor?
Any help greatly appreciated.
Rockstar
Old Oct 12, 2009 | 06:06 PM
inspectorcurly's Avatar
Car: 1992 RS Camaro, 1952 Dodge pickup
Engine: 3.1 and 305
Transmission: Auto Th-350
Axle/Gears: 3:42 in both
Re: Code 44 after replacement thermostat..
clear the computer by disconnecting the negative cable from the battery and then start, take for a drive and recheck the flash codes if still coding on 44 check connection at the 02 sensor and repeat above or remove sensor and clean and recheck. that's what I do before replacement worth a try
Chuck
Old Oct 13, 2009 | 06:18 PM
rockstar08's Avatar
Car: IROC-Z
Thanks chuck!
It was the o2 sensor, I attached a multimeter, the readings were very erratic, would shift rapidly from .55 to .25 then back and up when the temp gauge read 200+deg.
After reading a little about 02 sensors I discovered that they are not used by the ecu unless the system is in closed loop.
I guess when i repaired the thermostat, it enabled closed loop operation and the o2 sensor to come up to operating temp, so I would have seen it when the thermostat was missing.
I am about to take it for emissions testing, its been sitting in a garage for 8 years.
Have replaced oil with synthetic, 02 sensor and water temp sensor. Replaced the gasoline with Premium unleaded with 10% ethanol. The car comes up to temp well, and theres' a little blue plume when the car starts from the valve stem seals, which I plan on doing later some time.
Do you have any recommendations on getting through emissions testing?
Thanks Rockstar
specialized
Jun 18, 2022 09:26 AM
gta90
Sep 15, 2015 04:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
