Adding injectors to TBI
Old Nov 3, 2009 | 07:40 PM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
I know it's been asked but I keep searching and find nothing.
I want to change the fuel pump and add the TPI injectors to my TBI wiring harness and all I read is about repinning. What I want to know is why can't I just Add injectors and pump and be good to go?
Since the TPI is a batch fire system why wouldn't when the TBI signal says fire the injector be the same as batch firing. I know I would have to tap into a couple different connects as well but I looking for why it wopuldn't work to get a better understadning why not.
Old Nov 4, 2009 | 02:31 PM
Ronny's Avatar
Re: Adding injectors to TBI
I found this for you. I searched "drivers".
https://www.thirdgen.org/forums/dfi-...-8746-tpi.html
Old Nov 5, 2009 | 09:58 PM
efi-diy's Avatar
Why not convert to megasquirt with the 746/747 adapter board? This will solve all your issues with trying to drive port injectors.
http://www.diyautotune.com/catalog/m...e7f1874c25e8b1
It will allow you to plug a MS V3.00 with a MS2 processor directly into your harness with NO wiring mod's. Plug and play.
It looks almost like this board except the 746/747 is green in color. http://good-times.webshots.com/photo...03786106VdvqSv
Old Nov 9, 2009 | 09:23 AM
Ronny's Avatar
Nice to see Megasquirt supports TBI. If you go ebay you may find several differing MS. Older models vs newer models and the price will reflect that. Seems every couple years a new release.
Old Nov 9, 2009 | 10:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
MS support of TBI is iffy at best. No, what they are doing here is to scrap perfectly good GM ECMs for the connector and case. Much better off staying with a GM ECM over the MS.
RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Keith5
Aug 27, 2015 04:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
