93 lt1 troubles
Car: 77 and 79 Vette 85 Jag 93 Chevy p/u
Engine: 350 all tpi in vettes and jag tbi i
Transmission: 700r4 all but pu is 4l60e
93 lt1 troubles
might it be possible to run a 93 lt1 engine with a 7730 or 7727 ecm has anyone tried this any input helpful
Car: check
Engine: check
Transmission: check
Re: 93 lt1 troubles
RBob.
Re: 93 lt1 troubles
no e trans thats about what i was thinking no way to run with opti spark dizzy on 7730 correct
thanks for input
thanks for input
Car: check
Engine: check
Transmission: check
Re: 93 lt1 troubles
Yes, as far as I know the opti can not be run from an other then LT1 ECM.
I have know the opposite to be done. Where an opt disk has been mounted into a regular distributor. This allows an LT1 ECM to be used.
RBob.
RBob.
Re: 93 lt1 troubles
really appreciate your input I've been playing with the tpi and my nephew is wanting me to fix his 93 but i cant fix the box after he let the smoke out of it and he,s having a hard time finding an ecm for the 93, from what i understand they were somewhat uncommon and not very dependable
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
Re: 93 lt1 troubles
93......gotta love those one of a kind year cars!! I have been through one ECM i mine and it has less that 100,000 miles. around 85,000 I think. ECM went out around 70,000
Re: 93 lt1 troubles
i know this is a month old thread, but if you still need a ecm. me and a buddy just got done converting his 93lt1 z28 to a northstar caddy DIS and switched to a 727 ecm. so he has his stock ecm laying around. great upgrade i might add lol
if you need one, i can foward this to him.
88SS6SPEED
Nov 11, 2015 07:05 AM
