Maf Sensor Values
Old Nov 23, 2009 | 02:02 AM
rubee's Avatar
Maf Sensor Values
What are the average flow values (in grams per second) I should be looking for on my scanner for a 89 Camaro 305 TPI auto F code when at idle and higher RPM.
I have a Auto X Ray 240 scanner and the Maf reads 2240 G/S at idle and 6300 when driving at 53mph @ 1375 rpm. no error codes present.
Gary
Old Nov 23, 2009 | 07:39 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Re: Maf Sensor Values
I don't know the exact value, but it is MUCH lower then that(2240). I was told that it should be 20-30g/s!
Old Nov 24, 2009 | 05:15 AM
rubee's Avatar
Thanks mate,
My manual tells me similar, this is a strange one especially with no error codes present.
The car runs good except at about 1350 RPM in overdrive the car will jerk slightly as if the timing is retarded,
the car will acelerate away fine from there.
Gary.
Old Nov 24, 2009 | 10:07 PM
Car: 87 T-Top GTA
OK, so you got a scanner, Good! Try this thread. It MAY have some info that could be of use to you, GOOD LUCK!!
https://www.thirdgen.org/forums/tech...art-story.html
In here, there is a section regarding MAF problems, and diagnosing pros. on how to fix!
BumpaD82
Feb 26, 2016 02:57 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
earlpote
Sep 12, 2015 11:55 AM
