91-92 ECU differences?
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
I recently installed a hypertech chip in my 91 GTA, but the chip was for a 1992. It ran poorly and threw a code for cylinder select error. Is there is difference in the ECU's or is this chip crap??
Car: check
Engine: check
Transmission: check
Re: 91-92 ECU differences?
At the same time, did you use the adapter along with the stock MEMCAL when you installed the HyperActive chip?
RBob.
Engine: 355
Transmission: 4L60
My ECU has been replaced in 1994 I believe the sticker said. Which number do I need off of it to identify it?
Car: check
Engine: check
Transmission: check
Engine: 355
Transmission: 4L60
Engine: 355
Transmission: 4L60
I got it working!
Thanks for the guidance, I really appreciate it.
Numbah-1
Sep 12, 2015 08:57 PM
MikkoV
Sep 9, 2015 04:25 PM
