Injector pulse at wide open throttle?
Old Jan 24, 2010 | 12:08 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Looked around for a while, couldn't find an answer. Does the ECM still pulse the injectors at WOT or are the injectors held full open?
Old Jan 24, 2010 | 02:52 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: Injector pulse at wide open throttle?
still pulses.
Old Feb 5, 2010 | 02:09 PM
Ronny's Avatar
There is asynch mode and synch mode. In synch they alternate pulses as one fires on every other distributor reference pulse. If they cannot meet the A/F commanded I believe they both fire every DRP. If that is insufficient I believe they go static full on which is not good. I hope this is mostly correct.
Old Feb 6, 2010 | 01:35 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Thanks for the reply. Wondering if I can put a pushbutton switch on the control line from the ECM to ground the injectors and give it a shot of fuel when starting to eliminate the extended crank time. Really a nuisance when it's cold out. Still thinking though.
Old Feb 8, 2010 | 10:51 AM
Ronny's Avatar
enrichment during cold coolant crank I recall can be added in the .bin
Old Feb 8, 2010 | 12:57 PM
Engine: 450HP 355
Transmission: TH350
Assuming the bin is similar to the ones i use there is a cranking pulsewidth multiplier VS TPS table.
0% TPS is simply 1, but 25-50% TPS multiplies the pulsewidth by 2 and above 75% by 0 (Clear flood mode)
so tom3, i'd try holding it at half throttle while cranking, if that doesn't help then make sure your coolant temp sensor is working correctly.
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
mdtoren
Aug 16, 2015 05:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
