7730 to EBL?
Old Feb 14, 2010 | 03:29 PM
WagonmasterRuss's Avatar
Car: 1993 Caprice Classic "Woodie"
Engine: 350 TBI W/EBL Flash
Transmission: 4L60 S10 converter
Axle/Gears: 8.5, Torsen T2, 3.73s
7730 to EBL?
I have a TPI harness for a 7730 ECU, but I'd like to run EBL flash.
How much repinning would be needed?
Old Feb 15, 2010 | 08:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 7730 to EBL?
It is a bunch. To change from a '7730 harness to an EBL Flash harness, the three connectors get re-pinned down to two connectors. For a stock conversion a 4-out buffer and a knock filter (module) are then added in. They are internal on a '7730 and external on a EBL Flash ECM.
It is easier to start with a TBI harness and change the injector, TPS & IAC connectors.
We can supply the re-pinning guide for the '7730 to EBL Flash conversion. Several users including myself have done this swap.
RBob.
Old Mar 29, 2010 | 03:04 PM
Re: 7730 to EBL?
RBob.
Thanks RBob,
I'm running TBI now and want to go over to TPI. I like the TBI steup fine but I like to goof around with freak factor stuff!
I have a brand new 7730 harness, ECU and a bunch of Misc. Moates stuff that was given to me by a guy who gave up trying on his car.
I have talked to other folks who kept their TBI harness and just spliced everything in too. I guess if I butcher the TPI harness at least I'll have new connectors to work with....
Any tips on the best teqnique to splice the wires? I'm not much of an electrician but I know what a butt connectors does.......
Old Mar 29, 2010 | 05:04 PM
moorepwr's Avatar
Car: '69 Camaro
Transmission: TH200-4R
Axle/Gears: 12-bolt/3.73/Truetrac
Re: 7730 to EBL?
Thanks RBob,
My tips:
·Use non-insulated crimp splices instead of insulated
·Crimp the connector with a good pair of crimping pliers
·Solder the wires into the crimp sleeve
·Seal with heat shrink tubing.
The only catch here is to make sure that you put the heatshrink tubing on one of the wires first. I have no idea how many of these I've repeated because I forgot the heatshrink tubing.
I just haven't had good luck with the insulated butts connectors.
Old Mar 30, 2010 | 08:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 7730 to EBL?
Originally Posted by moorepwr
My tips:
I second this post for how to splice the wires. For under hood splices, the other thing I do is to smear a little RTV (sensor safe) on the splice before I cover it with the heat shrink. This provides a weather tight splice.
RBob.
Old Apr 14, 2010 | 05:07 PM
Re: 7730 to EBL?
OK, I'm sold.
Next question...
If I start off with EBL flash and TBI, the move to TPI, I assume I can just move to TPI and retune. When I switch to TPI I want to use batchfire.
Can I use an EBL flash computer with the batchfire mod on a TBI motor?
Old Apr 14, 2010 | 07:58 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 7730 to EBL?
OK, I'm sold.
Next question...
You shouldn't use a Port Mod EBL with a TBI set up. First reason is that the injector firing rate is incorrect. The second is that the PnH drivers are disabled for the Port Mod.
Note that the Port Mod can be added at any time. And the turn is a day. So if you want to run TBI for a while then just go with the EBL Flash. Then at a later date if you decide to go port just send in the ECM for the Port Mod.
By the time you change everything over from TBI to port the EBL ECM will be back in your hands to plug & play. On top of that, you may find that the TBI runs rather well with the EBL Flash and decide not to go port.
RBob.
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Quzyle
Oct 15, 2015 03:35 PM
92rsvortec350
Sep 16, 2015 09:12 AM
85Special
Sep 3, 2015 04:21 PM
