gen 6 dfi compatibility
Old Apr 1, 2010 | 06:56 AM
BigChris101's Avatar
Car: 86 IROC
Engine: 5.7 TPI
Transmission: TCI 700R4
Axle/Gears: Zoom 3.73
I have 86 Iroc that i converted to tuned port,I used gen 6 accel dfi. I want to pull the tuned port,and up grade to a LT1 i picked up with 6 speed.My question is will my dfi control the timing on the newer style motor,with crank shaft distributor? If so how do i wire it?
Old Apr 5, 2010 | 03:27 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: gen 6 dfi compatibility
Hi Big Chris, First off. The dist on the LT1 is driven off the cam, as is the water pump. The dist uses high res & low res optical sensors for cam and crank reference thus its name: Optispark. The ign. control of the gen 6 unit may not work with the optispark sys. Youll have to check voltage and waveform to know for sure. ACCEL has a tech line where you may get help. theyre number is 1 248 380 2780. good luck
Old Apr 11, 2010 | 07:01 AM
Car: 86 IROC
Engine: 5.7 TPI
hi ase doc thank you for reply and info it was helpful.
Old Apr 11, 2010 | 01:18 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Hey Big Chris, I was thinking about your situation and i think msd may make a crank trigger set up for the LT1. If I remember correctly, the gen 6 will work with crank trigger and the msd controller. It's not a cheap set up but it may work for you. Hope this helps.
Old Apr 19, 2010 | 05:51 AM
Car: 86 IROC
Engine: 5.7 TPI
thank you for responding i appreciate the info
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
my86bird
Oct 23, 2015 12:20 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
