Megasquirt msq help
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Megasquirt msq help
I am finishing up the tune on my Megasqirt II and we are having a little trouble getting the acceleration enrichment down right. I was wondering if anyone had any advise on how to get this down correctly (yeah I know that is a very vague question).
My buddy who is way more knowledgeable than me with this was wondering if anyone had a msq file that we could take a look at to give us a ball park estimate on what it should be set at.
Kevin
Kevin
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: Megasquirt msq help
form what i know accel enrichment should be set independly on each car depending on how does TB react on stepping the gas or MAP sensor reaction or combination of two so msq file form other car won't help you much
setting all to basic values given in megamanual is good start to tune it right for proper values for your setup
best regards
best regards
Engine: L98 350 TPI
I understand that they will all be different but with anything that is DIY like this all the input I can get the better. I just want to see what every one else is running to get ideas for things I may have over looked.
So if you could lets see what you have.
I will be happy to share what I have if anyone is interested.
With the MSII are you running straight TPS, MAP or both. Trust me kev it is a complete pain in the ***. Give me a call later I will stop over and take a peak. And dont hold your breath looking for a MSQ odds are your not going to get one to help you. also are you using mega tune or tunerstudio
mhaskell
Alternative Port EFI Intakes
Mar 20, 2006 11:30 AM
86bird_28v6_5spd_ramair
Aftermarket Product Review
Oct 13, 2001 09:57 PM
