Windows 7 ?
Old May 27, 2010 | 02:48 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Windows 7 ?
im currently running Windows XP and TunerPro RT, Moates flash & burn works fine. If i was to upgrade to WIndows 7 will it still work? without having to figure out why it doesnt?
if so then i wont upgrade.
anyone done this?
Old May 27, 2010 | 05:37 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Windows 7 ?
i was running it all in vista until a month ago... everything seems to work exactly the same in 7 except for the playback speed in TP... i can't seem to get it to pass ~65Hz when i could get a good 400Hz in Vista.
Old May 27, 2010 | 05:50 PM
Re: Windows 7 ?
did you do an upgrade to 7? cause yeah everything work fine right now but i want to upgrade to 7 but dont want to have any headaches with it.
i never even noticed the playback speed so i dont know what your talkin about.
Old May 27, 2010 | 05:52 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Windows 7 ?
i formatted my hard drive and did a clean install... no issues yet. CATS software requires that you install in winXP compatibility mode, but those all seem to work as well.
and the TP playback speed in V5, i really don't know what's up with that, but it's honestly not that much of an issue.
Old May 27, 2010 | 06:18 PM
EagleMark's Avatar
Re: Windows 7 ?
Usually if you wait for the first service pack from Windows new system you will be fine without a guess.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
