how to change igntion module
Old Jun 10, 2010 | 07:00 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
simple question where is the igntion module and how do i change it,, its not a coil in cap rotor.. please tell me i dont have to pull the distributor
Old Jun 10, 2010 | 10:49 PM
Ole Ed's Avatar
Re: how to change igntion module
You dont have to pull the distributor. If you take the cap off, then the rotor, look below where the rotor was and see that black thing with the wires comin from it. Thats the module. It has 2 screws that hold it down. Remove those and lift it up.
Old Jun 15, 2010 | 01:23 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
also, make sure when you replace it to put some dielectric grease between the module and the distributor housing. it will help transfer heat and keep it alive longer
Eric2ndGen
Nov 5, 2015 01:51 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
crazynights
Aug 21, 2015 06:53 AM
