4-wire flat connector on Ignition for timing
Old Jul 21, 2010 | 02:25 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
Th is may be the wrong place to post this, but I was wondering if any of you knew where to pick up a "new" (new being a relative term) 4-wire flat connector, the one that you disconnect (from the distributor/ecm) to set base timing. I can't find this thing anywhere.
The reason I ask is that the end where it goes into the distributor is getting pretty hacked up (the connector more than the wires) and I would like to get a new one before trying to "fix" it myself. I've looked at "new" and refurbished distributors both from Autozone and Classic Industries, but they all have a 3-wire connector that's not flat. Any help would be greatly appreciated!
Old Jul 21, 2010 | 06:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 4-wire flat connector on Ignition for timing
With the re-furb distributors odds are that is a standard picture. As they wouldn't be a drop in or work with only a 3-wire connector.
For the connector, check NAPA. They carry some pigtails. Other places on the 'net is eficonnection and RosesAndWrenches. Ballenger Motor Sports also carries some connectors.
RBob.
Old Jul 21, 2010 | 08:56 AM
Ozz1967's Avatar
Car: 1984 Trans Am
RBob.
Thanks RBob, I'll check into it. The side that's coming apart is not the flat connector but the part on the other end that plugs into the distributor. The 4-wire flat connector and the ECM wires are all fine....it's up on the distributor itself that I'm seeing the problem.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
camaro71633
Sep 1, 2015 10:24 AM
