question about resetting the comp
Old Aug 15, 2010 | 12:53 PM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
Axle/Gears: 95 z 3.42
My question is, if you change the fuel press or timming, do i need to clear the comp memory?
Old Aug 15, 2010 | 01:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: question about resetting the comp
When the fuel pressure is changed it is best to do a reset. This is to clear the BLM values which will now be different with the change in injector flow rate.
RBob.
mz92274
Aug 25, 2015 08:47 AM
mdtoren
Aug 23, 2015 12:52 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
