What can cause no spark please help
Old Aug 16, 2010 | 04:10 PM
Jon92camaro's Avatar
ive bought a new coil new cap plugs and wires these other parts have nothing to do with spark i dont think but this is what else ive gotten that my 92 camaro needed idle control valve egr valve battery altenator um im pretty much stumped i cant take the car to get codes for it no money to get it towed so
Old Aug 16, 2010 | 08:45 PM
82crossfire305's Avatar
Car: 1982 Trans Am
Engine: LU5 CFI
Transmission: TH-200C
Re: What can cause no spark please help
did you set the distributer up correctly, im pretty sure theres a certain firing order number that you start it at before setting the cap in place, unsure tho. also check to make sure all ur wires and plugs are correctly in place
Old Aug 16, 2010 | 08:57 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
have you checked for spark at more than one plug? or right off the coil? could be ign module too, you can take that in to a parts store to check, make sure they check it a couple times to see if it fails when its hot.
If your getting a check engine light, search on here how to read them off the adld.
Old Aug 21, 2010 | 04:32 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
You don't need to take it anywhere. All you need is a paper clip, pad of paper and pen or pencil. If your check engine light is on, your system is trying to tell you something. That's where you should be starting.
If you get a code, you can either search here, or simply do a Google search. As an example I just punched up "GM code 42" and the search brought up several links to note that the ignition module is a concern.
Here's a link as to how to go about reading them.
http://www.obd-codes.com/faq/read-gm...codes-free.php
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
