upgrading ecm but where to start!!!
Old Sep 13, 2010 | 09:36 PM
Shane87irocz's Avatar
Car: 1987 IROC-Z
Engine: L-98 350 TPI
I have a 87 iroc with a L-98 350. I am wanting to upgrade my ecm but not sure where to start... I am amusing i have a 165 ecm and i can upgrade it to a newer ecm used in 88/89. If i do this what do i need and how hard is it to wire it up??? How much does this cost??
Also it i was to do a Mega Squirt II Ecm what do i need and what is the cheapest way to do this with out building my own kit.. Seams like a lot of work to build.... A list of part # would be greatly appreciated for both kits. Thanks Shane!!!
Old Sep 13, 2010 | 09:57 PM
AmorgetRS's Avatar
Re: upgrading ecm but where to start!!!
Why do you want to upgrade your ECM? The 165 was used until 89, just used the 6E instead of 32/32B which eliminated the cold start injector in 89 (plus a bunch of other things changed). You can upgrade to that without upgrading the ECM.
Old Sep 13, 2010 | 10:05 PM
Car: 1987 IROC-Z
I was told the i would benefit from a different ecm because its faster/easy to tune and would have more tuning options.
Old Sep 13, 2010 | 10:23 PM
AmorgetRS's Avatar
There are a lot of people that tune the 165's.
Is your car stock or close to stock?
Old Sep 13, 2010 | 10:47 PM
Car: 1987 IROC-Z
no where near stock. Min Ram,AFR's,cam the list goes on...
Old Sep 13, 2010 | 11:33 PM
AmorgetRS's Avatar
Well, you can swap to a 730 or stick with the 165.
Since you already have a TPI EFI setup I wouldn't think that going with Megasquirt is going to gain you much. You can do basically anything with the GM ecm as you can with MS.
I'd suggest you read all the stickies on this board and the DIY PROM before touching anything else.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Jae992
Aug 27, 2015 09:07 AM
86White_T/A305
Aug 17, 2015 12:16 AM
