no communication
Old Nov 12, 2010 | 02:13 PM
KS91Z28's Avatar
no communication
I've done a few searches, but haven't found a good answer to my exact problem. I'm working on an '87 IROC. The engine runs great, but the temp gauge is acting funky so I wanted to hook up the Snap-On scanner so I could see what the temp sensor for the ECM was reading. The scanner says "No communication", however, I can jump the terminals to make codes flash with the SES light. Any ideas?
Old Nov 15, 2010 | 11:41 AM
Ronny's Avatar
Re: no communication
ign on engine off does the SES-CE light blink once then solid on? If yes that tells you ECU should be OK as well as the chip.
Old Nov 15, 2010 | 12:14 PM
KS91Z28's Avatar
Yeah, the check engine light does the blink once then solid on thing. I think I may have figured out the problem over the weekend. I'll update this post when I verify.
Old Nov 15, 2010 | 08:22 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Ok, what if i turn the key into the "on" position and then i just get a solid engine light? I do not have the single blink and then solid on. I just have the solid on. Also, i can not connect with any software programs like Datamaster or Freescan, or EFI live. I even had a Max 232 aldl cable built professionally and have also tried the simple two transistor circuit with no success. Do you think I may have a bad ecm or prom? If so, which one?
Old Nov 16, 2010 | 10:45 AM
Ronny's Avatar
ign on - solid light means you are not running off prom. rapid blink is a defective prom.
Old Nov 16, 2010 | 09:58 PM
ninetyone's Avatar
Axle/Gears: 3:42
ok, just checked again, i do get a super fast single blink then a solid light. Still no connection through aldl port. Any ideas? I even tried orange wire on the ecm A8.
Old Nov 17, 2010 | 09:29 AM
Ronny's Avatar
That is normal. Runnin off the prom. Can you cause the CE/SES light to come on by (?) disconnecting a sensor as a test?
