What is the C237 connector for?
Old Jan 8, 2011 | 09:20 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Does anyone exactly what the c235 connector is for?
Old Jan 8, 2011 | 09:24 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Re: What is the C237 connector for?
A picture or at least a location of where it is would be a great help.
How many pins, color wires going to or from, etc.
Old Jan 8, 2011 | 09:25 PM
its by the c207, thats passenger side, near ecm. Its a 4 wire connector, with a tan and white wire, and 2 pink/blk wires
Old Jan 11, 2011 | 02:19 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
C235 is part of the cruise control circuit. It connects to the multifunction lever harness. Are you sure you have the number right? C235 has one pink/blk, a dk blue, a gry, and a gry/blk wires. It is located by the streeing column.
BTW, this thread is confusing. You title the thread: "What is C237 connector for?" Then you say you're looking for description of C235. I spent several minutes looking for and identifying C237 before I realized you were looking for C235. Guess I should have read through the thread before I went looking for the answer to your question.
From the wire colors and location of the connector you describe, it sounds like C221, which is the power supply to the injecor harness and 12v ignition to the primary side of the fan relay(s).
Old Jan 11, 2011 | 05:14 PM
They show a c235 on austin thirdgen on the c207 connector page, its a 4 wire, and the c221 is a two wire. I have a 4 wire that looks like c235 near the c207, with a pink /black, pink and white wire.this part of the harness is for an 88 v6 bird, and my ecm side is from an 87 camaro TPI
Old Jan 11, 2011 | 05:15 PM
sorry ASE Doc, i meant c235, sorry for any aggravation
Old Jan 18, 2011 | 01:41 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Did you get this figured out?
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
