potential tuning needed?
Old Feb 24, 2011 | 01:00 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
So i have to get some valve work done soon. my l98 is jumping between 15-20"hg when i run a vacuum test. chances are I'm looking at either a bad valve, damaged seat, or carbon buildup. what I'm looking at doing is throwing some 2.02/1.60 valves in the stock heads then getting a decent bowl blend but first I want to know if this would require some computer tuning or not since the cam isn't being changed. car is a 91 With a 350 and speed density.
Old Feb 27, 2011 | 11:34 AM
Engine: L98 and L03
Re: potential tuning needed?
edited to add some more pertinent information
Old Feb 28, 2011 | 04:40 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
even a dead stock motor can benefit from some custom tuning...
if you can get a good datalog, you'll know if your fueling is off or if you're experiencing excessive KR, both of which more or less require tuning(unless you play with the FPR or adjust the timing mechanically).
IROCZ1989
Jan 24, 2016 03:55 PM
ezobens
Aug 19, 2015 10:29 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
